Inventor Forum
Lofted surface transition
13 REPLIES 13
Message 1 of 14
923 Views, 13 Replies
When creating a loft between two curves, I am not able to control the top and bottom portion of the surface created, I have joined a picture of the part and my IPT file with the problem I got.
Thank you for your help.
Daniel P,
13 REPLIES 13
Message 2 of 14
whunter
Don't loft, rather sweep the two profiles, and then shell them to obtain the correct thickness.
Message 3 of 14
M.Peppel
Hi Daniel,
please find a sample of the desired part attached. It was build with the 2009 Version of Inventor so you should be able to open it.
cheers
Matthias
Nihil Ex Nihilo
Message 4 of 14
Thank you for your solution, but in my part there are three differents sketchs at each end and the top of the part is not flat. That's why I used surfaces to create the curved top.
Thank you.
Message 5 of 14
johnsonshiue
Daniel,
I took a quick look at the model. I personally think this can be done easily by extruding a Y-shape profile. Then draft side faces. Would it work better?
Thanks!
Software Test Engineer
Message 6 of 14
JDMather
Here is a quick attempt.
I think I would use some 3D intersection rails to get it correct.
Your sketches were too complicated for me - edit your first sketch and see how I simplified it.
Message 7 of 14
whunter
See attached attempt. The surface looks OK, but I cannot make a solid of it.
Message 8 of 14
JDMather
in reply to: JDMather
Here is another attempt.
I might use this as a guide to start over.
Message 9 of 14
JDMather
And a variation on Walter's - but I didn't really like the fillets.
Message 10 of 14
JDMather
Any progress on this?
Message 11 of 14
Thank you very much M. Mather
I agree with you about the simplicity of the sketchs. This part was originally modeled with Catia and I have tried to use the same dimensioning that I found on the original drawing.
Your solution #1 is more acceptable to me because I need a shell thickness of .05 inch. In your rev. 1, I am unable to create a shell as low as .001 inch.
I think it would be simpler if I had better control of the lofted surface in my original IPT file.
Daniel P.
Inventor 2012 sp1
Windows 7 64 bits
8Mb Ram
Message 12 of 14
JDMather
I'm sure if you used rails you could get better results and should be able to shell to any thickness down to where the fillets (which I would do as fillet features, rather than sketch fillets) near zero radius.
Give it another try and if you don't get better results I will see if I can find time to improve the part.
Message 13 of 14
Thank you,
I will try with your recommandations this weekend and I will come back with the results.
Message 14 of 14
Finally got it with JD's recommandations.
Thank you very much.
Daniel P.
