Inventor General Discussion
20 Kudos
Post 1 of 7
Lofted Flange Ducting help
277 Views, 6 Replies
02-22-2013 04:52 PM
I am trying to create a ducting chute and am having trouble creating a lip on the end.  I have drawn it simply using a boundary path and thickening but know that it will not unfold.  I know I can probably "cheat" and get something close but was wondering if somebody could take a look at the attached assembly (drag the eop markers down) and help me create the chute lip.  It should be sheetmetal and be allowed to unfold.  I am presently not sure which direction to pursue.
Rob
2,129 Kudos
Post 2 of 7
Re: Lofted Flange Ducting help
02-23-2013 04:01 AM in reply to: RobJV
You forgot to attach the part files.
Part must be created from planar, cylindrical or conic faces only or with the Inventor Sheet Metal tools.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
20 Kudos
Post 3 of 7
02-25-2013 10:09 AM in reply to: JDMather
Sorry - was in a hurry Friday afternoon and grabbed the wrong file.  The zip file should be attached.
20 Kudos
Post 4 of 7
02-25-2013 10:12 AM in reply to: JDMather
Thanks JD - I am pretty adept at sheetmetal and most other parts of Inventor and understand how sheetmetal parts work - just having trouble figuring out a good way to construct the lip that I have shown as a representation only.  (Zip is now attached.)
Rob
Product Support
32 Kudos
Post 5 of 7
02-25-2013 02:06 PM in reply to: RobJV
I took a look at the parts you attached and not sure if sheet metal could do this due to the unfolding rules and reliefs it would need.
Don.
20 Kudos
Post 6 of 7
02-25-2013 02:09 PM in reply to: 4donwan4
Thanks for taking a look anyways.  I may end up just doing some approximations if nobody else has any bright ideas.  JD?
20 Kudos
Post 7 of 7
02-27-2013 12:26 PM in reply to: RobJV
I played with it a bit more and adjusted the lofted flange end sketch and then created a contour flange lip that should do the job.
Rob
