Jake Fowler
Principal Experience Designer
Fusion 360
First, thank you. Your answer above was helpful.
I have a similar problem, except that I'd like to create a single loft to tangent curved surfaceS! Can you please help me?
I have two tangent, curved, surfaces (two tangent cylinders of different radii). Inventor shows a line where the curves intersect and treats the surfaces on either side of that line created by the split (following the steps you layed out above) as seperate surfaces. I can only select a single surface for the loft, when I would like to basically merge those surfaces.
Please see the attached part file. This is just an example for the sake of simplicity and doesn't follow any good design conventions, but it illustrates my problem.
One example.
