I'm trying to draw a sketch on the side of this downtube, but cannot because it is both a lofted feature and there's also a fillet in the region where I'd like to draw the sketch. Once the sketch is drawn I want to loft it to the side of the cylinder. Any gurus in here that can school me on how to accomplish this?
Create 2D sketch on planar face and then use to Split the face to use for Loft or get 3D sketch intersection (Project).
1. What is the "planar surface" you're referring to?
2. I've never done the "split face" operation. What is that?
1. Workplane or planar face of part.
2. I have a bunch of tutorials here http://home.pct.edu/~jmather/content/DSG322/inventor_surface_tutorials.htm
I appreciate that you have many tutorials at the link, however, I just perused them and see nothing that pertains to my situation. Additionally, like you I also work a primary job during the day and try to work on this project evenings and weekends. Time is short and I don't have weeks to dig through umpteen tutorials viewing information that isn't going to help me overcome this problem and if by chance I do find something I'll spend days trying to learn how to perform the operation which drags me further off course from my original problem.
So is there a more direct means of finding the information I need or not?
Take a screenshot, scribble on it to mark up what you're trying to accomplish. Reading through what you've written here has left me somewhat unclear on your end-state objective.
Rusty
Thanks for your response.
I'm trying to put a .75 fillet on all 4 of the long lofted edges, top to bottom.
Additionally, I'm trying to connect the cylinder to the nearest side of the structure, beginning roughly .65 above the facedraft extending approx 2 inches up from that point.
Hope that makes sense...
if I were you, I would start over. unless I am missing somthing, I believe you only need one extrusion for the major portion, then fillet that with your 3/4" fillets, then use the bottom surface as a reference for your cylinder and bracket, then loft the bottom to the round it looks like you have.
if it is as simple as it looks it should take no more than 10 minutes.
its hard to understand the issues you are having when there is only one view and no idea of the size.
