Hey all,
Fairly new to Inventor and any CAD software for that matter and thus learning the software as I use it. I am currently working on a drawing of a flow loop test device and am running into trouble connecting some of the "duct work" pieces using the loft command. The first picture below shows the overall drawing and where the connections are needed. The next picture shows what I would like the connections to look like. Once I hit "OK" on the loft I get the error message of:
Create loft feature failed
FlowLoop.ipt: Errors occurred during update
Loft4: Could not build this Loft
The attempted operation had problems trimming and discarding faces. Try with different inputs.
I have tried remaking the sketches which are used to make the connections with no luck there either. Any help would be much appreciated. The 3rd attached file is the .ipt of the drawing.
Keith
Solved by JDMather. Go to Solution.
You are sort of doing OK, but too much work.
I recommend start experimenting with multi-body solids as this will really end up being a solid.
You still model in one part file all the solid bodies - but then they will be pushed out to an assembly.
For your problem - Loft the inside curves as a Surface Body and then Thicken to the outside by the desired wall thickness.
The CADWhisperer YouTube Channel
Thanks for the quick reply. I appreciate the help with my current issue and tips for making future projects like this!
I have one follow up question. Once this is complete and I go to create a new drawing, I notice the lofted portions of the piece do not show up. Any ideas?
Keith
Did you Thicken the surfaces into Solids?
Have you installed all Service Packs and Hot Fixes/Updates for 2012 (iProperties indicates the answer to that is No).
Thickening the surfaces took care of the visibility issue, thanks.
I have not installed any Service Packs or Hot Fixes/Updates to my knowledge. What do these gain me and where can I find them?
Pardon my ignorance.
Don't take this the wrong way - but this is how I found the site
http://lmgtfy.com/?q=autodesk+inventor+2012+service+pack
There is also are also documents explaining what these fix.
BTW - I was just looking at the feature in question and it looks like to me a Revolve might be appropriate (and more basic geometry) rather than Loft. Just an idea - I didn't take time to investigate closely.
