Hi I am having trouble creating a part, I want this to evolve with the design requirements in real time so I created many sketches that can be modified within the loft. I am having trouble getting the loft to work, specifically where a sketch has two separate shapes that I would like the loft to split and follow each individually. I am not sure if I have been searching the wrong words, but I cannot find a solution online. Any help would be great I have attached the file so you can see. Thanks
Do you have an image of a similar part.
I don't think you are using the most efficient technique to achieve your design intent.
I do not have an image, is it possible to connect two shapes on the same plane? How would you recommend to accomplish this?
