Kevin Vallelunga wrote...
"I'm trying to loft between these two faces and get this error. It will loft
with the default setting under conditions but when I change it to tangent
transtion and any weight value I get this error. I will try to post to CF.
Any thoughts? I tried to create rails with a tangent spline but it wanted to
include the lines in the sketch that the spline was created tangent to. No
option to make them(the lines) construction geometry in a 3d sketch?"
One problem is point mapping related. Inventor uses a piece to piece
mapping algorithm; e.g. edge_1a is matched to edge_2a, etc. A more
sophisticated software will offer options that may yield an acceptable auto
solution, but you will have to create the map points manually.
(See attached.)
Another (possible) problem: It appears (can't see the details in the pic
very well) you are working with solid bodies and trying to create quilts.
If you pick an internal quilt (or "solid") edge as a U wire (section)and
specify a tangent condition how does inventor know which surface / face is
the seed? Since you can't tell it (assuming this is still true in v8) I
guess it's a 50/50 deal.
If these are imported parts there will probably be other, more subtle,
undetectable factors negatively influencing the outcome.
If I were doing something like this in inventor I believe I'd....
(1) Delete the sheet capping faces. (2) Loft the transitions between the
major faces. (3) Go back and fill in the gaps. (4) Stitch it all together.
Alternative if you are trying to create a single solid.....
(1) Pick the sheet capping faces for use as sections. I believe that
inventor should properly identify the adjacent faces for tangency seed
faces. (2) Define all your mapping points and loft as a solid. (I'd try
this first with simpler shapes, but I think the chances of success with your
shapes is iffy. Actually, my usual approach would be to delete all but a
set of control faces for each body, create the transition, stitch and
thicken. I don't think you want to attempt this in inventor, though.)
Anyway you go about it you'll have to settle for G0 edge continuity in the V
direction, which you may or may not see as a problem.
Re using multi-segment curves for rails: After clicking on the sketch,
click the desired segment a second time to select. Not sure this is
necessary, though. Although rails must intersect the section curves I don't
think they must terminate on a section curve (not sure and too lazy to
test). At any rate, I don't see a need for rails for what you are doing,
though could be missing something.
