Hi
I am following the U-Tube exercise called "Emergency Light (Cabinet) volume 1".
I am at time stamp 1 hour 26 minutes, exactly.
In the video they use a Loft command in order to cut a shape out of two sketches numbered 10 & 11.
I have been copying exactly and am having difficulty at this stage of the model.
Is there any reason why I am managing to use the Loft command earlier perfectly but not at this point.
I would appreciate any help from anyone.
Kind regards
A CAD Student.
Solved by JDMather. Go to Solution.
Change everything that is projected in Sketch10 to construction linetype.
Are you sure two of those corners in Sketch11 are not supposed to be filleted?
what is the url of the YouTube video?
All you need to do from U-Tube is enter this description.
"Inventor Emergency Light"
Please take a look at time stamp 1 hour 26mins.
before commiting.
Kind regards
CAD Student
@Anonymous wrote:All you need to do from U-Tube is enter this description.
CAD Student
No, all you need to do is paste the direct url here.
Good luck!
http://www.youtube.com/watch?v=cBu3UjXG_cM
This is the url please have a quick look for me I want to finnish my model.
Were those two fillets I added supposed to be there as I suspected?
