Inventor General Discussion
New Member
Mesainc1
Message 1 of 3 (523 Views)
Loft command giving me problems
523 Views, 2 Replies
01-10-2013 11:40 AM
I am trying to use the loft command to go from Sketch 3 to Sketch 4, but with the output on solid, it gives me this error. "The attempted operation had problems trimming and discarding faces. Try with different inputs."
I am using Inventor 2012 professional. The loft commands I am using are "Join", "Rails" "Solid Output"
Valued Contributor
EScales
Message 2 of 3 (510 Views)
Re: Loft command giving me problems
01-10-2013 12:24 PM in reply to: Mesainc1
It won't work because you multiple loops in each sketch.  If you edit the sketches and changes the inner loops to construction lines, it will work.  You'll get a solid loft and then you can use the shell command to hollow out the inside and maintain your .100" wall thickness.
Eric
Please select "Accept as Solution" if this answers your question.
New Member
Mesainc1
Message 3 of 3 (503 Views)
01-10-2013 12:32 PM in reply to: EScales
That worked great. Thank you very much.
