Inventor Forum
LOFT command gets crazy - not taking data
3 REPLIES 3
kmeldfreyssinet
334 Views, 3 Replies
I have just discovered that "LOFT" dose not work properly, that is how expected.
When profile on sketch has more than one closed regions loft command gets crazy.
Is this problem known? and some workaround?
I post ipt wit sketches prepared for loft that I can not do.
Cris.
3 REPLIES 3
admaiora
in reply to: kmeldfreyssinet
Hi Cris,
it's not a software problem, loft work on loop profiles.
So in every your sketch there are 2 closed loops. If you choose the external you will choose only the external loop with no internal island.
To make the selection work, you have to select firstly the sketch, then the loop that you want.
Thant in the loft windowd "cliack to add " to go on.
Finally onother loft with cut option
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
JDMather
I think I would use only two profile sketches and one guide rail sketch.
kmeldfreyssinet
in reply to: JDMather
I probably would also use one sketch and guide rails. But in this particular model it is more complicated and this approach I took seems more easy this time.
Cris.
