Inventor General Discussion
razortje777
Message 31 of 36 (322 Views)
Re: Loft between 3D sketch and normal sketch
12-24-2011 01:24 AM in reply to: wolterh6
Hello JDMather
I have 'researched' your loft.ipt file and try to copy it step by step in my own CAD file from the cylinder.
But a few things I don't understand:
Where can I find the option 'Edges' in the menus?
What are the functions of those 3D lines you have drawn?:
When I thicken the wall-surface for instance with 10mm to the outside (to get a cylinder wall), how can I let these 'holes' filed up so that they are smooth rounded around the inlet ports?:
Thank you in advance!!
JDMather
Message 32 of 36 (317 Views)
12-24-2011 05:05 AM in reply to: razortje777
I did not know whether the information you provided before was to the inside bore of the cylinder or the the outside.
I was simply providing a quick example.  (For example, I didn't bother to get those sides between the ports created by parallel lines with parallel sides).
To model the actual geometry I would have to know more information and spend a day or two on experimentation.
Edges are edges of existing geometry by selecting a face or a surface.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
razortje777
Message 33 of 36 (301 Views)
12-28-2011 02:08 AM in reply to: JDMather
Thank you for your answer.
But I don't understand it quit well. For question 2 and 3 I'm still looking for an answer because I don't know yet how I could fill those 'holes' up arround the inletports.
And I have searched again for more then an hour but I can't find the option 'edges'. Could you please let me know where to find it?
Thank you.
razortje777
Message 34 of 36 (295 Views)
01-02-2012 12:04 PM in reply to: razortje777
I am sorry that I reply another time, but after days of searching on the internet, help topics... I still can't find that option 'edges'
And also the other problems, I can not solve.
I hope that someone could help me find that option, and could help me solve those other problems.
Thanks in advance! I really appreciate it, because it get's me a bit frustrated this problem after 2 months :smileysad:
JDMather
Message 35 of 36 (291 Views)
01-02-2012 12:27 PM in reply to: razortje777
When you select a face or a surface Inventor selects the Edges.  Edge selection gives more functionality than sketch selection.
You should put your part aside for a bit and go through the tutorials in my signature.
Especially this one
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
and this one
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%207.pdf
razortje777
Message 36 of 36 (270 Views)
01-03-2012 09:48 AM in reply to: JDMather
Thank you, now I finally found the 'edge function' and therefore I was able to draw the inlet ports.
For now, the cylinder is finished exept for one last anoying thing...
For some reason I can't 'Thicken' the cylinder wall, or 'extrude' it between the two sketches...
Could you please help me with this last step?
Then this model is finished, and I will start with some Inventor courses to learn more of it (basics for instance).
Here is the file:
http://wtrns.fr/tioDo-2-CpBxt6
Hope you really could help me with this last step.
Thanks in advance!
Gr,
Lennart
