Inventor General Discussion
New Member
0 Kudos
Post 1 of 5
Loft Advice
442 Views, 4 Replies
01-20-2013 08:06 AM
Im struggling coming up with a loft or sweep to get the design effect I need. Please see on the pic how the profile terminates to a point. Any help or advice would be appreciated
Just a real quick 5 minute attempt, but you can get some ideas from it.
29 Kudos
Post 2 of 5
Re: Loft Advice
01-21-2013 06:09 AM in reply to: SPGMATT
I am a beginner myself, and I am sure someone will come along and give you proper advice, but I'll give it a bash later on.
I'll try a 3d sketch intersect to create the lifted bit, and maybe use split to try to loft bit by bit around that tight corner.
Cheers
772 Kudos
Post 3 of 5
Re: Loft Advice
01-21-2013 08:33 AM in reply to: SPGMATT
Create your round end first, most likely a Revolve to form the end Button. Then create your Sweep from this. You should be able to copy the outer edge of the Button onto the sketch for the profile of the Sweep
IV2015 SP1-ud2 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-980 Classified - 347.09
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
Distinguished Mentor
201 Kudos
Post 4 of 5
Re: Loft Advice
01-21-2013 11:51 AM in reply to: SPGMATT
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
New Member
0 Kudos
Post 5 of 5
Re: Loft Advice
01-23-2013 02:49 PM in reply to: mpatchus
Thanks for your help Mike, I got it
Steve
