Inventor Forum
Locking the display location of sketch dimensions
6 REPLIES 6
tony.rainsberger
638 Views, 6 Replies
Hello,  I making a rather complicated sketch in Inventor to send to a laser cutter.  I want to place and lock the location of displayed sketch dimensions; however, Inventor automatically reorients these display locations frequently (ie when I finish the sketch, move around nearby dimensions, add additional elements to the sketch, etc).  Is this behavior controlled by a default setting?  If so, where can I find this setting?  Thanks in advance for any advice.
6 REPLIES 6
JDMather
in reply to: tony.rainsberger
Do you need to see the dimensions?
Maybe convert to a Sketch Block.
Cadmanto
Hi Tony,
No, but what you can do is copy the sketch to a drawing and rearange the dimensions there.  In the drawing they will stay where you place them.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
tony.rainsberger
in reply to: Cadmanto
Thanks Scott.  That works like a charm and has application for a wide range of situations.
Cadmanto
You're most welcome.  Glad it worked out for you.  Smiley Happy
Best Regards,
Scott McFadden
Benjamin
Hi Scott,
Has this functionality been added to inventor yet or is there any plans to? I think it would be very useful!
johnsonshiue
in reply to: Benjamin
Hi Benjamin,
Unfortunately, it is not yet available. The sketch dimension or model dimension can still move arbitrarily when the geometry is changed. I believe there might be ideas on Inventor Ideas forum. Please vote for it.
Many thanks!
Software Test Engineer
