Inventor Forum
Locking a view in Inventor drawing .dwg when placing views
6 REPLIES 6
3029 Views, 6 Replies
First off, I am using Inventor 2012.
So I created an assembly in Inventor and now I am creating a drawing for it in Inventor.  I have a few views placed of the same assembly.
Is there a way to lock one view in the assembly?  For example, my assembly consists of a door, I would like to have one view with the door open and another view with the door closed on the same drawing using the same assembly link.  Is there a way to do this?  Like is there a lock feature somewhere in Invetor that I can accomplish this?
Thank you in advance!
6 REPLIES 6
BarryZA
What you really want are positional representations, which you control in your assembly.
Once you set that up you can choose which positional rep/level of detail/view rep you want to show in your drawing.
and or use overlay to ghost different positions in a single view.
in reply to: BarryZA
So I created a position representation.
This might be a stupid question, but how do it edit a view to be able to choose which position rep/level of detail/view rep that I want to show?
Is it best to do this from a new view or can I fix this from a current view?
BarryZA
RMB on the view - edit
or double click on the view, you will see drop-downs for the reps.
So I've figured that out, the problem I am running into now is about creating view representations.  I am trying to create one for when the door is open and the other for when the door is closed.
Here is how I did it so correct me if I am wrong:
I set up the view to the way I want it, with the door closed.  I then went to Represenatations --> View and right clicked and hit New and created View 1.  I then right clicked the new View 1 and hit lock.  I did the same for View 2 with the door open.  When I double click to change between the two, it shows them both with the door open but with a different angle on the assembly.
I have no idea what I am doing wrong so any help will be appriciated.
jtylerbc
As you stated in the quoted portion of your post, you created a View Representation.  This is not the same as a Positional Representation.  View Representations control camera position, component visibility, and color overrides.  Technically, the View Reps you created are doing exactly what they are supposed to.
You need to be creating Positional Representations instead, as BarryZA indicated.  Positional Representations are listed in the browser just below where you created the View Representations.
in reply to: jtylerbc
Thank you guys for your help, I have figured it out now.
