Inventor General Discussion
Distinguished Contributor
JimSteinmeyer
Message 1 of 6 (1,035 Views)
Locked Dimensions?
1035 Views, 5 Replies
11-14-2012 02:55 PM
I have a part made by a former co-worker that appears to have some dimensions locked. The second feature on the attached file is a pair of rectangular cuts. I would like to edit the dimensions of the hole, but when I sellect a dimension I am unable to enter any numbers in the dialog box. Can someone suggest a solution?
We are on 2013 now.
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
If you are editing the sketch some dimensions may become driven. Try and make the dimensions that not are already driven, driven, by selecting that dimension and then selecting driven dimension on the ribbon. This willl allow you to select and make the dimension you were originally trying to edit, an udriven dimension (by selecting that dimension and then again selecting driven dimension from the ribbon).
Valued Mentor
rhasell
Message 2 of 6 (1,033 Views)
Re: Locked Dimensions?
11-14-2012 03:22 PM in reply to: JimSteinmeyer
Hi
I had a look, I can modify every dimension, so is this problem on this part only? (I am not sure if this behaviour could be from Vault or perhaps a network drive, I don't use either, so I am guessing?)
It might actually be eaisier to re-model the part, The sketches are not constrained correctly, and you have point to point dimensions (Ex AutoCAD user?)
You can then apply material properties at the same time  :-)
Sorry I could not have been of more help.
Reg
Autodesk PDS Ultimate 2015 SP 1 Build 203
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please Give Kudo's / accept as a solution if it solves your problem.
JDMather
Message 3 of 6 (1,027 Views)
11-14-2012 04:27 PM in reply to: JimSteinmeyer
I don't see a Hole feature on that part.
What dimension - can you be more specific?  Each dimension has a variable name.  Are you referring to d103, the 19.353 dimension?  That is a driven dimension (reference).  Driven dimensions can't be edited.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
New Member
mblankman88
Message 4 of 6 (985 Views)
11-15-2012 10:55 AM in reply to: JimSteinmeyer
JimSteinmeyer
Message 5 of 6 (948 Views)
11-16-2012 08:26 AM in reply to: mblankman88
JD, sorry instead of hole I should have said cut. The specific dimensions I was looking to change were d104 and d19. interestingly enough, when I attempted to edit the dimensions today, they worked! I don't know what happened but when I attempted to change them the other day I could select the dimension but when I went to edit it the current dimension would show again and the curser would show at the end of the dimension and not allow anything to be entered.
Jim
HP G71 notebook
Win 7 home premium
JimSteinmeyer
Message 6 of 6 (947 Views)
11-16-2012 08:30 AM in reply to: rhasell
Reg,
So far this is the first time I have seen this behavior, and as I mentioned to JD, it appears to have dissappeared and things act as usual. The operator who origionally created this part is our Lasor programer  who has a lot to learn about working in 3-D. ;D
Jim
Jim
HP G71 notebook
Win 7 home premium
