Deal all,
How to lock between 2 parts in Inventor as it in Solidworks logo like keylock? So it will move together.
FNB
Solved by nmunro. Go to Solution.
am not sure what you mean by "keylock" in Solidworks. I did a google search on this and didn't come up with anything. I have used SW for 12 years and unless that is a command that has come out in the past couple of years, I have never heard of it. I can read into what you are saying and it almost sounds like constraints in Inventor. If not can you geive some more detail as to what exactly you are trying to do?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Ok, I remember that now. When you called it keylock it didn't sound familiar at all.
In Inventor, if you RC on a component there is a command called (Ground) . That freezes the component right where it is.
Your right, I guess I have been away from it too long.
Then I am not familiar with that exact command you are speaking up in SW. What I can suggest is use a series of constrain commands to accomplish this. If that doesn't work maybe you can place an idea in the Inventor IdeaStation that is similar to SW and what you are used to.
