I am currently updating a title block and it will be wider than the original. This is going to cause me to move the block.
How do I get it constrained back into the lower right hand corner? I wouldnt think this would be this difficult of a thing to accomplish.
Hi avaya2012,
Depending on the change it will likely automatically update, if not I think this link will answer your question:
http://forums.autodesk.com/t5/Autodesk-Inventor/Custom-title-block-position/m-p/3506430#M439097
I hope this helps.
Curtis
Curtis,
Can you elaborate on this procedure with set insertion point grip? I am not having any luck.
Not exactly. I had a new custom titleblock, and I was trying to locate it on the drawing in a certain location. This drawing template also did not have a border which seems like the title block has nothing to snap to. I really want the ability to place the title block wherever I want on the drawing.
@Anonymous wrote:
.... I really want the ability to place the title block wherever I want on the drawing.
In that case, I think creating as a Sketched Symbol might be appropriate.
