Inventor Forum
Local update button
2 REPLIES 2
jeremyj
745 Views, 2 Replies
Local update button
I made a signifigant change to an assembly that messed up several constrants.  I fixed all the constrants using the red cross button but the local update button is still lit up and won't do anything when I click it.  Does anyone have any ideas?  Thanks
2 REPLIES 2
emily.xu
in reply to: jeremyj
I think there still have some errors in your assembly that prevent the update. My suggestion is to suppress the components one by one and find the failed one, then try to fix the problem.
If you can share your data, that would be better to help with your issue.
Emily Xu
Product Support
jeremyj
in reply to: emily.xu
Thank you emily, that worked great.  I never thought about trying that.  You're the best.
