Hi everyone,
I installed Inventor Professional 2012 on my new notebook (Packard Bell, AMD Radeon HD 7670M). Inventor works fine until I try to load a new drawing of an .iam assembly group. It works fine with any .ipt part.
I read somewhere that I had to copy a file from the 64bit windows directory to the system32 folder but that didn't work since it was for an other program (with a similar problem).
Thanks for your help,
Manuel
The error says something about loading the library? Are you using Content Center items in your assembly? If so, it sounds like Inventor is looking for the library that those CC parts came from and cannot find it. Is your notebook on the same network as the machine where the assembly was created?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi, thanks for the response.
I am not using any Content Center items and i am not part of any computer network.
p.s. i now tried to load an assembly group and there is no problem doing that (even if some content center items can't be found). The problem just exists in .iam drawings.
