I recently updated from Inventor 2010 to Inventor 2011 and the look of my parts and assemblies are missing the black outlines on everything. I'm sure its a simple box that needs to be checked I just don't know where it is. Can someone help?
See attachement. I want it to look like 2010...
Solved by mcgyvr. Go to Solution.
Thanks for the reply Stephen! My only problem now is that it only works for the file that is open. Is there a way to set to apply to all parts and assemblies?
Terry
@terryp wrote:Thanks for the reply Stephen! My only problem now is that it only works for the file that is open. Is there a way to set to apply to all parts and assemblies?
Terry
tools..application options..display tab..settings button.. change to shaded with edges.. hit okay..then check "use application options" instead of use document settings
Easy Street and Ocean Blue color schemes are now also available for 2012
http://teknigroup.com >> Downloads
