Does Inventor (2012) have the option to view sketch constraints as a list? I feel like I am playing pictionary trying to find out what constraint is what and what it is constraining and it doesn't help that Inventor stacks anything nearby on top of each other.
I've attached a file showing what the problem is, please don't judge the model tree. I was prototyping as I went so it is messy.
Hi!
But why you want to view all the constrains at the same time??!!
You have diferent line color to diferenciate what's constrain and what's not. Also in the bottom wrigth, you have the information regarding constraining.
Also you can active view the constrains for isolate geometry members, use this tool: "Show Constrains".
and you will have the same information, less confusion.
About the list, you have the description on the help about all kind of constrains, but if you continue practicing, believe me, you don't need any list for that... just practice. Tip: When you start a new sketch, constrains the firsts elements you draw, and it will be easier to control your sketch. Always "Full Constrain" the sketch.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
The sketch constraints shown in your screen capture do not make logical sense.
Attach your ipt file here.
The CADWhisperer YouTube Channel
This is not about how to use the constraints, I want to know if I can view a list. I also don't see how they aren't logical, almost every one in that sketch is a Symmetric, Vertical, Horizontal or Parallel constraint...
Carlos, that button does make it easier but I would still like to see a list.
Something like the image attached instead of pictures everywhere on the sketch.
Hi!
In addition to the usual places, you have lot's of quick ways to access the constrain's information and manage.
You doesn't have a list nor a function to delete all the constrains in inventor, but... you can select wich constrains you want to delete at the same time quickly, and i think you have good visual information regarding constrains... besides, which cases we need to delete all the constrains!?
Like i said, is a matter of habituation to a different software. You can't have the better of the two in one...
I feel your pain, I do not believe Inventor sketch constraints are implemented as well as the competitive software. I would hope this feature is introduced in new releases, as it is much easier to work with.
Before anyone asks, I have been using Inventor for 3 years now and this is one of the features I miss most.
Add the parameter function to your quick select toolbar. Then you have 1 click access to your parameters.
I apologize in advance if 2012 does not support this, but from memory you should be able to add it to the toolbar. If not, then just select the parameter function from the ribbon bar.
Stephen R.
Hi
I'm not sure if 2012 have this feature but you can try
select your line close (very important) to the coincident constraint you want to delete and RMB select delete coincident constraint
