Solved by JDMather. Go to Solution.
Not sure why you would be adding a lip and groove to a drawing, they should be on the part.
Also make sure you have all Service Pack's installed.
Have you installed all Service Packs? (you didn't respond to this part of blairs response)
Can you attach the file here and see if others can reproduce the behavior?
Click Reply
Click Browse lower right corner.
Find file to attach.
If it is too large to attach here (over 1.5Meg)
first
find the red End of Part marker at the bottom of the feature history tree.
Drag the red EOP to the top of the browser hiding all features.
Save the file in this rolled up state.
In Windows Explorer right click on the filenane and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here per the instuctions above.
