Inventor Forum
linking text to an iProperty
4 REPLIES 4
PBailey
464 Views, 4 Replies
Does anyone know if it is possible to link an iproperty to a text field. I'm creating an iPart factory and I would like to emboss the part number on the surface and have it automatically change with the iPart that is created. The only way that I could think of to do this would be to have the text in the text box to be pulled directly from the iProperties. Any help would be appreciated.
Thanks.
4 REPLIES 4
pgannon18
in reply to: PBailey
I've done this using a unitless parameter, but our part numbers are formatted: [base number]-001, 002, etc. It was on an iPart that only had a few versions so I was able to use this method. I don't think you can use iProperties though.
LOONYLEN
Does anyone know if this has been added or addressed yet?
I need to emboss part numbers from my iproperties on my parts.
Len
Senior Designer/Cad Administrator
Inventor 2012, w/SP2
Vault Collaboration 2012
Dell Precision T3500, Intel Xeon CPU
W3680 @3.33GHz, 16.0 GB of RAM
Microsoft Windows 7 Pro, 64 Bit Edition
Version 2009, w/SP1
BMiller63
in reply to: LOONYLEN
Mark Randa has provided the iLogic code to do this here:
http://opendesignproject.org/Inventor/iLogic/Text_Manipulation/index.php
along with the sample files:
http://opendesignproject.org/Inventor/iLogic/Text_Manipulation/TextoChango.zip
and a video:
http://www.youtube.com/watch?v=Y5a8IYyxFLo
this really needs to be a built in solution (hint, hint Autodesk!)
mcgyvr
HINT HINT (just incase they didn't see Bmillers hint)
