Version??
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
wrote in message news:5694259@discussion.autodesk.com...
I have an assembly with 3 .IPTs. One of the parts ("dummy part") is just
used to export parameters to the other two and contains work planes that I
use to constrain the other 2 parts to it in the assembly. If I choose to
export the "dummy part" user parameters (which is what I want. I'll explain
why if any shows interest) I run into major problems because the 2 parts
that use these exported parameters don't update. Doing a rebuild-all
doesn't help. If I export MODEL parameters they update fine when the "Dummy
part" is changed. Why are USER parameters over looked during an update?
