> {quote:title=osheske wrote:}{quote}mcgyvr
> excel works fine seperately. i can access excel files previously linked prior to the windows 7 upgrade. i just cannot link any new excel files. this is very fustrating. i am almost dead in the water now. i am looking into installing XP Mode, but i think it may cause further fustration.
> paul
No one can help you but Autodesk for this issue. Too bad they completely misled you already by publishing an article claiming support for Windows 7 when they aren't ready for it. This article made you (and many others) believe you could install W7 without issue but infact that is not the case.
I beleive Autodesk should either make it priority #1 to immediately release the required hotfixes/service packs or publish a retractment claiming they jumped the gun on this. Too bad neither will happen because they are a large company and can do whatever they want with little to no consequences.
You should submit a support case with a critical status and complain till you are blue in the face. or remove your w7 OS and install Vista or XP. I would really suggest removing w7 and not reinstalling it till 2011 is out or Autodesk addresses all the issues (which might not happen till then anyways).
I was flaming mad when I saw that article about Windows 7 support. I knew that many users like yourself will read that as Inventor works on 7 already and install it because you have it just ready to go.
