Hello everyone,
I have a part that needs some parameters' values of another part, so I linked them. I also place this part in an assembly using an ilogic rule which runs in the assembly. After placing that part, I use something like:
iLogicVb.RunRule("partName:1", "ruleName")
to run the part's rule, which changes it according to the linked parameters. The problem is that the values of the linked parameters are not updated to the current values. They are whater they where the last time the document oppended and whatever I tried the dont update before the rule copletes. the only workaround I found is to use somethng like:
dim myVar as integer
MyVar = parameter("partname.ipt.OriginalParameter")
instead of making the link.
any ideas?
Thank you in advance.
