I can link numeric values from a spreadsheet to parameters.
However, is there a way to link text from a spreadsheet into iProperties (or
anywhere else as text)? I'm trying to administrate general information\metadata from a
spreadsheet.
I do not think this is possibible from within Inventor, but maybe someone have an macro\ilogis\vba code that do this??
br
Svein
Solved by Curtis_Waguespack. Go to Solution.
Hi SveinE,
Here is an example iLogic rule to do this:
GoExcel.Open("C:\Temp\MyExcel_WB", "Sheet1") iProperties.Value("Project", "Part Number") = GoExcel.CellValue("B1") iProperties.Value("Project", "Description") = GoExcel.CellValue("B2") iProperties.Value("Project", "Revision Number") = GoExcel.CellValue("B3") iProperties.Value("Summary", "Comments") = GoExcel.CellValue("B4")
where the excel data looks like this:
I hope this helps.
Curtis
Thanks Curtis
It looks like this will dp the trick.
I will try and let you know 🙂
br
Svein
