Inventor Forum
Link parameters doesn't work
2 REPLIES 2
Karol-Or
343 Views, 2 Replies
I made 2 parts, c cylinder and a plate with a hole, and tried linked the Diameter parameter in the Cylinder file.
First, i chose the Diameter, in the link dialog box, but the new user parameter that was inserted was the file name only.
Secondly, when i activate the Hole parameter in the plate file and select List Parameters in the Equation column, i see only the Hole parameter, not the new one, the Diameter, which i tried to link.
So, the link doesn't work.
But, i have, also, a general question: why do i see, in both files, in the List Parameters dialog, only the parameters which i changed their names? i expected to see all the parameters of the part, no?
2 REPLIES 2
rdyson
in reply to: Karol-Or
Open the parameters dialog in your plate.ipt
RMB on the linked file and edit folder
Choose which parameters you want to link.
If they aren't already exported, you'll receive a warning. To avoid this, first export the parameters in the file you're going to link.
PDSU 2016
Karol-Or
in reply to: rdyson
Thank you very much
