Inventor Forum
Link beteween inventor part and autocad file.
4 REPLIES 4
indalkar.dattatray
560 Views, 4 Replies
Spoiler
Spoiler
I have create link between inventor model or drawing to autocad . Is it possibel?
Spoiler
Means If i change the inventor model autocad should also get changed accordingly.
Spoiler
If it happen it will be very helpfull for me.
Spoiler
Pls help me.
Spoiler
Spoiler
Thanks in advance,
Spoiler
Spoiler
Datta Indalkar.
With Warm Regards,
Datta Indalkar.
4 REPLIES 4
You don't have to put everything in spoilers 🙂
If you create a regular .dwg drawing rather than .idw drawing, you'll be able to open it in autocad
Product Design Suite Ultimate 2021
Dear Sir / Madam,
Thank you very much for your help. I have started using dwg file in to inventor .
But Inventor running very slow in dwg than idw. Is there any setting for the same.
pls help.
Thanks in adavance.
Dattatray Indalkar
With Warm Regards,
Datta Indalkar.
Names from different countries can be hard to tell the gender of. I happen to be male, so it would be sir 😉
I haven't experienced my inventor becoming slow because of that.
You can try a few settings, either under "Hardware" tab, or "Drawing" tab.
I'll upload a file with a setting you can try and change as well
Dear Mr.. yannicknielsen,
Apoligize for not calling you with proper name.
Your suggested option is not with my inventor ( inventor professional 2011)
file contains some autocad blocks. Is it happen because of autocad blocks? File size has become 31 MB.
As opened the file memory shows yellow indicator &  As soon as placed two or more views in the sheet  it turns to red  low memory.
For more clarification PFA file on which I am working.
Pls help me to get rid of  this problem.
Datta Indalkar
With Warm Regards,
Datta Indalkar.
