Inventor Forum
lineweight
8 REPLIES 8
Message 1 of 9
2153 Views, 8 Replies
lineweight
Having created a custom drawing border ,i find when printed that certain lines are printed to thick,what i need to do is
make these lines thinner for better defintion.
In Autocad this is simple but what is the process in inventor,do you change the colour or specify a user lineweight,where is this done?
Regards
8 REPLIES 8
Message 2 of 9
BarryZA
Manage-styles editor-layers.
As long as you have set up a template that is read/write you can make changes. Make sure when you save (just next to styles editor), you save your new setting in place of the default one.
I can't tell you the exact sequence of save/update because I usually get it wrong a couple of times.
Then I usually save the updated blank drawing as a template.
Message 3 of 9
JDMather
The Styles and Standards Editor is for you overall drawing views (2D from 3D).
For editing your border/titleblock go into the Drawing Resources, edit and right click on anything you want to change the Properties of.
Message 4 of 9
mrattray
in reply to: JDMather
There are layer options that control your title block and border line weights in the styles manager. Editing the line weights through the line's property menu is actually setting an override.
Mike (not Matt) Rattray
Message 5 of 9
JDMather
in reply to: mrattray
Let's say you are creating your own custom border/titleblocks (not using the built it) - when you are in the sketch how do you assign layer?  (I have always done borders/titleblocks by overriding the Properties.) Your post just prompted me to take a closer look, but somehow I am missing this step.
More:
I just edited one of the built-in titleblocks and found that the thin lines have a Line Weight override.
And More:
OK, I do see how to assign one layer By Standard (Border) to new border, but still looking for TitleBlock and what if I wanted Zone Border to have thin ticks?
Message 6 of 9
mrattray
You can create new layers in the styles manager:
And assign different layers to different gometery:
Message 7 of 9
JDMather
Ah, yes.  I always did it manually and was curious how the built in titleblocks were created.  They did the same thing I did - overrode the lineweight Properties of individual lines.
Message 8 of 9
Did you ever receive an answer on this? I am having the same issue.
Message 9 of 9
johnsonshiue
Hi! This is a very old posting. I thought the prior replies already addressed the question. Do you mind sharing an example showing the issue or start a new thread? Your issue may not be exactly the same as OP's, although you may think it is.
Many thanks!
Software Test Engineer
