Inventor Forum
Lines do not connect for extrusion
3 REPLIES 3
3989 Views, 3 Replies
All of a sudden, my line tool in sketch mode does not connect segment to segment and each individual line can be dragged wherever. This also means I cannot extrude any shapes I make because inventor does not realize the series of line segments create a closed shape. This happens across all part files, old and new.
Any ideas? Thanks!
3 REPLIES 3
Additional info: when I try to close a shape, the green dot doesn't come up; it is still the yellow and if I try to close by clicking on another line, it still gives me another segment to place after. I tried reseting settings by clicking on Default Inventor settings in options to no avail...
trumpy81
Are you using Inventor 2013?
Click the drop down triangle beside constrain on the ribbon bar, and select Constraint Options. Make sure everything is ticked.
Hopefully that will sort out the problem for you.
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
in reply to: trumpy81
thanks! that worked!
