I'm assuming you are in the model sketch environment. If so, then there are
a couple of new icons that control the linetypes available, one being the
centerline you are looking for that will allow a diameter dimension when
sketching revolves. Check out the default toolbars and you will see them.
"askrobia" wrote in message
news:25445555.1096504996947.JavaMail.jive@jiveforum2.autodesk.com...
> Ok, I'm a student at VA TECH and we use inventor, My version 7 wasn't
working so I got the new upgrade to 9. My problem is that the tutorial book
that we use for inventor is based off of version 6. It was helpful with the
version 7, but a lot has changed between version 6 and version 9 obviously.
> So, my question is this, in the tutorial it says to right click inside the
graphics window, and then it shows a selection of "Linear Diameter" being in
the menu that pops up, however in version 9 that selection isn't there.
Only the options of done, Edit dimension, previous view, isometric view, and
hot to show up. So where do I go to get the Linear dimension? I need this
in order to revolve the object to create a symmetrical pulley, or so the
tutorial says. Is there another way to do this?
> Thank you for all of you help.
