Hello:
im not sure what i changed but when im trying to sketch a line usuly the little cuser turns from yellow to green when it snaps to an edge or a center. but its not snapping can you help me with trying to get my line snap back. thank you
- Mike
Solved by JDMather. Go to Solution.
You haven't stated what version of Inventor you are using (my guess is 2010).
You have either turned off Constraint Persistance or Constraint Options.
A search here on those terms might turn up a video.
See attached.
RMB to get to Constraint Options.
You haven't stated what version of Inventor you are using (see first response).
What happens if you Right Mouse Button while editing a sketch? (see 4)
Why two thread on the same topic?
I had the same problem as this thread with line snapping. version 2011. what solved it was the right click of mouse and clicking "constraint options" and "selcting all", I was lost for about 1 week. trying to learn contraints made me click it off and mess me up. problem solved, thanks
