Is it possible to get a Limit/Fit tolerance included in a Hole Note call out, such as H7 etc?
Currently, when I am dimensioning Counter Bore holes, I have to use a general dimension for CBore dia incuding the Limit/Fit tolerance and manually add the hole dia (or visa versa). This means I have to manually update any changes to hole dia.
Conor.
Solved by warrentdo. Go to Solution.
In the model select the hole.
in the dia box select the little blue arrow fly out on diameter and select tolerance.
in the tolerance type select limits fits show size type then select H7.
If you then go back to the idw and select your hole note, precision and tolerance / tick the use part tolerance.
This should then show the diameter with the H7 dimensions.
Cheers
Warren.
correct!
but why don't let the option in the hole note tollerance as well?
Hi All.
This is my first post and it's reather old topic, but I stucked with this one. Althought the sollution by Warren works on normal parts, it has no effect on derieved part unfortunatelly.
Any suggestions?
Thanks!
Ok, found it! You just need to Export the Parameter of the Hole Dia. from Base Part, and derieve it in derieved one.
