I am trying to special paste a Excel Table on a IDW. when I copy (Ctrl+C) the table is large, but when special pasted into IDW, the rows and columns are cropped after certain number. Is there a setting to show the entire table?
Whats weird is, when I double click the table after pasting, it does open up in a Excel application & I can see the complete data. But when returned back to inventor it shows the cropped table. Same problem with insert object also. Table getts cropped.
Solved by mcgyvr. Go to Solution.
@CAD-One wrote:
any one else expirence this issue?
yes. Its supposedly an Mircosoft OLE limitation (or so I've heard over the years..)
You can do a few things..
#1 try paste special instead of inserting the excel object.
#2 use smaller font in the excel document
#3 break the table up into smaller ones
#4 use inventors table command where you can create a table from an excel table ..sort of...(note there are tons of limitations to this too.. no merging,etc..)
I've written about it a few times here..
@CAD-One wrote:
Thanks for sharing the work around. I believe I should split the data into multiple tables.
Try the paste special first..
But yes splitting into multiple tables is the best solution IMO when paste special doesn't work.
