Inventor General Discussion
Valued Contributor
methoni
Message 1 of 6 (388 Views)
Accepted Solution
Lifting analysis
388 Views, 5 Replies
03-14-2014 06:19 AM
Some clarification regarding lifting analysis is required.
A simple steel frame has been modeled  with  one lifting eye at each end ,the centre of gravity is central to the single point lift.
Knowing the weight of the frame and the geometry of the lift rope one can work out the force on the lifting eyes and the force direction to create a vector diagram.
When analysing the frame this information can be entered and the force on each lug added together with its angle.
The question is this ! Does inventor automatically add the frame weight into the analysis in which case the forces would then be the frame weight plus the vector forces or is there a toggle to omit the frame weight.
Any suggestions.
yannick3 wrote:
Hi
If i remember Inventor does not add automaticly the body weight but use body load feature in the load tab
Use Gravity.
yannick3 wrote:
Hi JD
the op is not on the simulation environment
In the fea environment the tool to simulate the gravity is body load
Everywhere I look?
Valued Mentor
yannick3
Message 2 of 6 (379 Views)
Re : Lifting analysis
03-14-2014 06:36 AM in reply to: methoni
Hi
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Valued Contributor
methoni
Message 3 of 6 (377 Views)
Re�: Lifting analysis
03-14-2014 06:43 AM in reply to: yannick3
Thanks Yannick
I will investigate that further.
Regards
*Expert Elite*
JDMather
Message 4 of 6 (360 Views)
03-14-2014 07:35 AM in reply to: yannick3
yannick3 wrote:
Hi
Use Gravity.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Mentor
yannick3
Message 5 of 6 (333 Views)
03-14-2014 12:14 PM in reply to: methoni
Hi JD
Yannick Verreault
INV PRO 2015
MS Office 2007
WD caviar black 1To
*Expert Elite*
JDMather
Message 6 of 6 (326 Views)
03-14-2014 12:33 PM in reply to: yannick3
yannick3 wrote:
Hi JD
Everywhere I look?
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
