I make this part for electrical box .Do i have the proper workflow to create this part?
Stll learning
Looks good to me, simple first sketch that makes use of the origin planes. Use of Mirror for the corner features and holes. Some might have broken the Emboss to a simple sketch for one of the side "ribs" and used the Array and Mirror commands to produce the remainder of them and treated the center Emboss on it's own. Should someone what the side "ribs possible made smaller and more of them for visual appearance.
There'll be some trouble, if you try to shell your result.
But you can solve this by changing the follow-up of features.
Walter
Walter Holzwarth
Thanks you for valuable input.
wh i use Inventor 2014.Is your example 2014
Regards
greg
Yes, 2014 data.
But I've seen now, that your initial file was 2013. It's no big deal, doing the same steps in 2013, if needed.
Walter
Walter Holzwarth
