Inventor Forum
Licensing Concerns
16 REPLIES 16
Message 1 of 17
326 Views, 16 Replies
Licensing Concerns
We'll R6 finally arrived here this morning so we should have it up and running here by the end of next week. Problem is we installed out final licence of R5.3 two weeks ago and have not been able to authorise it becase AutoDESK have upgraded our licenses and wont issue an authorisation code for it's installation.
We are on the subscription package and it seems that as soon as the new version comes out, AutoDESK upgrade our licenses at their end with regards to authorisation codes etc. This is fine except that it took over 6 weeks for our R6's to arrive after release (actually arrived on the 27th November). What would have happened if we had to do a reinstall in between of R5.3? We would have had no software. It also leaves us in the position that if we had decided to skip the introduction of R6 (not sure why we would) and just continue to use R5.3, we could not have reinstalled R5.3 if they needed it, nor could we have gone back to R5.3 after installing R6.
This is not good enough.
Regards
Steve
16 REPLIES 16
Message 2 of 17
Steve,
I have various licensing scenarios here (local and
network) and have always been able to run the old versions toether with the new
releases. Why would you loose the old license?
Leo Laimer
Maschinen-
und Fertigungstechnik
A-4820 Bad Ischl - Austria
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
We'll
Regards
Steve
Message 3 of 17
I don't know why you would not be able to reinstall
R5.3, don't you have a copy of the authorization code?
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Message 4 of 17
We do have copies of the authorisation codes, but the software asks for a new one each time it is loaded onto the machines. Our VAR states that they can't issue an authorisation code for R5.3 as they have ugraded our licence to R6.
When the IT guys originally set them up there were numerous conflicts with Outlook, requiring several startovers on the systems. each time they needed to contact our VAR to get a new auth code. I don't know if this is something to do with CDilla or not.
regards
Steve
Message 5 of 17
I'm not sure that we would lose the licence Leo, but I think it is an authorisation code issue. If the VAR or AutoDesk or who ever, wont give us an authorisation code for the licence we have, the licence is useless. It's not a problem if the comoputer doesn't crash and we don't need to reformat and start again, but if we did, we may be forced to upgrade because we can't get a new authorisation code.
Regards
Steve
Message 6 of 17
Sounds fishy...I can reformat my whole HD, reload
and use the same Auth Code.
We
regards
Steve
Message 7 of 17
Our IT guy confirmed that he had to get a new Auth code every time he re-installed the software. I can only go by what they say, not having done it myself. What could be missing or being done incorrectly that would require a new Authorisation code every time you reformat and reload?
Regards
Steve
Message 8 of 17
Sorry, I don't believe it.  I've re-installed
many times while trying to trouble-shoot/correct hardware problems.  I use
the same Auth Code over and over again.
DM
Our
Regards
Steve
Message 9 of 17
Maybe our IT guys need to try harder . Seems strange to me as well.
Regards
Steve
Message 10 of 17
Sounds like the C-dilla troll.
(the ever-popular licence-manager from hell).
US-versions dont have this beast, and can use the auth-code again and again.
Us others, (at least europeans) have to endure this silly abomination. When we rescieve the auth-code, were told to keep it because we'll need it to re-install, but of cource it doesnt work that way.
I also have to get a new code to install on a new or changed machine.
Most of the time however, on a machine with a valid license, you can uninstall and reinstall IV without using the auth-code.
A format of the hard-drive should also be OK.
Jorgen
Message 11 of 17
Yeh Jorgen   I think your right.
Steve is from Australia.
Sounds
again.
A format of the
Jorgen
Message 12 of 17
I most certainly am from the land of Oz :). The main problem for us at the moment is that Adesk or the VAR (don't know which) wont issue an Auth code for a 5.3 licence, because they have sent us R6. Hopefully we can get R6 up and running on all three machines we have here soon.
Regards
Steve
Message 13 of 17
Steve,
In order to avoid most problems with the licenses,
it is best to export them prior to do some major changes on the PC in question,
and to reimport them afterwards. Should work without problems, I've done this
several times now.
Please note: The license is tied to the NIC adapter
number!
Leo Laimer
Maschinen-
I
Regards
Steve
Message 14 of 17
Leo,
I'm pretty sure the license is tied to a few more things than that. I
assume it's a bit like Windows XP as my home computer doesn't have a NIC in
it and I can import and export the license to it with no problems.
Cheers,
--Rob Singlehurst
"Leo Laimer" wrote in message
news:D974333A39BE7210A3DC942CF156777F@in.WebX.maYIadrTaRb...
> Steve,
> In order to avoid most problems with the licenses, it is best to export
them prior to do some major changes on the PC in question, and to reimport
them afterwards. Should work without problems, I've done this several times
now.
> Please note: The license is tied to the NIC adapter number!
> Regards,
> Leo Laimer
> Maschinen- und Fertigungstechnik
> "sstrik" schrieb im Newsbeitrag
news:f127c0d.10@WebX.maYIadrTaRb...
> Regards
> Steve
Message 15 of 17
Well,
Suppose this is a topic Adesk wouldn't like to see discussed publicly that
much...
I was told by a tech guy, that it's tied to the NIC, and that - with many
cheap NIC products - you can change this NIC number with a tool, so you
could clone your license. I've not tested this, as I have more licenses than
employees at the moment.
Leo Laimer
"Rob Singlehurst" schrieb im
Newsbeitrag news:A608953CC70707632D898CCAC7D3A95A@in.WebX.maYIadrTaRb...
> Leo,
in
> Cheers,
> --Rob Singlehurst
> > Steve,
times
> now.
> > Regards,
> > Leo Laimer
> > Regards
> > Steve
Message 16 of 17
Could you be confusing it with Pro/e?
They used to tie the licence to the mac-adress on the NIC.
Message 17 of 17
No danger of confusion due to my lack of knowledge
of Pro/E <g>
But maybe there got something mixed up between
network license and standalone.
Leo Laimer
Maschinen-
Could
