<broken record>iparts</broken
record>
The library content is NOT the way to go if
your company need to maintain standards.
If you are really bored you can insert 1 of EVERY
instance into an assembly and then go through and change the properties of each
nut, bolt, dowel pin etc... But everyone in your company has to use the
same set of library parts from that point on.
like I said before...iParts
