Hi all,
i need to create large number of parts library in 'stl' format - approx. 28 part types and 18-20 parts size in each type. I would appreciaeted advise on best way to do it - better than my plan - iParts and than 'save as' each created part.
Solved by VinodBalasubramanian. Go to Solution.
You could create the iparts and then migrate then as a batch through task scheduler. I still feel creating iparts is faster than any other option provided if you have more similar geometries.
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-ABE8A8DD-5D06-4B60-815C-CF386DD457D9
Hope it helps. I will see if there are any better ways other than this.
Good day to you.
Just wanted to check with you for an update. Please let us know, if you need further assistance.
We will be glad to assist you further.
Your understanding and support is greatly appreciated. Have a great day !
Vinod.
