I am using Inventor 2014. Some how the library Smooth - Black was changed and I am not sure why. The Local color is correct but the library one changed. Is there a way to fix the library color back to the local color?
Solved by cadcamm99. Go to Solution.
I fixed it. I copied the materials using it to local materials. Then removed the materials from the library. Then removed the color from the library. Then copied the local color to the library. Then copied the materials back the the materials library.
