As Johnson Shiue pointed out, you can't currently "lock" an LOD (good idea btw), however, you can copy the LOD to the View Representations and lock that VR. In this scenario, your suppressed LOD parts will become hidden, the biggest draw-back is that you will loose that memory management (hence those objects will load into memory) and you'll likely suffer on performance for very large assemblies.
