Inventor Forum
Let a wheel roll in a randomly shaped rail
5 REPLIES 5
1200 Views, 5 Replies
As you can see in the attachment (which is a small test version of my full project) do I have a problem..
The wheels on the side need to roll inside the guide rail. I can let them roll in each part separately but not in the entire rail.
I already tried with transitional constrains but then inventor says that there are some problems.
My project needs to become a sectional gate so there's going te be lots more than just 2 wheels in it...
Hope someone can explane me how to constrain this movement
5 REPLIES 5
mpatchus
Try creating a continuous surface (as a seperate part) on the inside of the guide rails.
Constrain the wheels to this surface instead of the rails.
Turn the visibilty of the surface off as needed.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
mrattray
Don't double post. It's bad karma..
hhttp://forums.autodesk.com/t5/Autodesk-Inventor/Constraining-to-a-random-path/td-p/3669326
Mike (not Matt) Rattray
I'm sorry but it did help... He gave me a good tip which i didn't get on the other post...
Mpatchus: The rail is made by sweeping along a continous axis but in the assembly it always gets divided.. How can i make a continuous surface that wont divided in the assembly?
jingyi.liu
Well, I guss you want to get  a animation, I prefer to use Inventor Dynamic Simulation to get such kind movement.
You can leverage the joint (sliding:Curve & Point), attached please fiind the iam file , I made some changes on your dataset, simpliified the assembly  and modified the guiderail part,  since it requires a close loop.
Inventor Professional 2013
Jingyi Liu
Inventor Product Manager
jingyi.liu
Also modified attached part to create a sketch point.
Jingyi Liu
