I am looking for help with Autodesk Inventor. A model imported from Solidworks needs to be "stretched" about 1 cm longer to accomodate some wires from a board to an LCD. I want to add length to the model at a plane through a particular region, as shown in attatched pictures, without changing the geometry of the rest of the model. Appreciate any help.
Thanks, dbw
Solved by Curtis_Waguespack. Go to Solution.
Hi davidbwhyte,
It might depend on your version, but here is how you would do it for Inventor 2010 - Inventor 2014:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-53BF57D8-352B-4689-AE42-8C1BBCE38F92
I think you can do the same thing mentioned above in Inventor 2015 also, but that version also has this:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-E27FC7F0-1224-491C-84C2-EC2AE77171A2
I hope this helps.
Curtis
