Inventor Forum
Length Parameter In iPart Description
11 REPLIES 11
Message 1 of 12
rob.j.ross
2042 Views, 11 Replies
I have a Length parameter that I would like to use in the description of a simple iPart.  I can enter the equation with the parameter into the Description field in the iProperties and it calculates correctly.  When I add the description column to the iPart table, all members get the same description as the active or current member even though all the Lengths are different.  Regenerating all members does not seem to correct it.  I have done this before but don't remember what am I doing wrong.
____________________________
Inventor Professional 2014 64 Bit
Windows 7 Professional
NVIDIA Quadro FX 4600
Dual Intel Xeon E5540 CPUs
16GB DDR3 Ram
11 REPLIES 11
Message 2 of 12
cbenner
in reply to: rob.j.ross
It looks like the value and not the actual equation populated to the ipart table.  Try manually typing the equation into one of the instances, and see if it propogates properly (tongue twister!).  If it works, you can copy and paste the equation into the rest of the rows.
Message 3 of 12
rob.j.ross
in reply to: cbenner
You cannot type the equation directly into the iPart author column (see error) but you can do this if you edit the table via spreadsheet and create the equation in Excel.  I thought this could be done without entering an additional equation in Excel?
16GB DDR3 Ram
Message 4 of 12
rob.j.ross
To get all iPart members to use their specific lengths in their specific descriptions you must put the equation in Excel.  I thought this could be handled by the built in fx equation capability in the parent part description but apparently not.
16GB DDR3 Ram
Message 5 of 12
P_Korgaonkar
Hello Rob,
This post shows as solved.
But I can see the solution.
I am trying to do the same with no luck.
Did you find the way to achieve this?
Regards
Parag
Message 6 of 12
P_Korgaonkar
in reply to: P_Korgaonkar
Sorry for Typo.
I meant I did not see any solution.
Regards
Parag
Message 7 of 12
IgorMir
Hi Parag;
The thread is four years old. Yet I too am keen to see a solution to your question.
Cheers,
Igor.
@P_Korgaonkar wrote:
Sorry for Typo.
Regards
Parag
Web: www.meqc.com.au
Message 8 of 12
Mark.Lancaster
in reply to: IgorMir
@P_Korgaonkar
The video https://www.youtube.com/watch?v=gIcn601F6TQ at the 34 min mark that walks you through how its done..  In the beginning it was formatted incorrectly but 2nd attempt (it worked Smiley LOL)
Although a given posting was marked as the solution, the real solution is the reply above the solution.
Mark Lancaster
Message 9 of 12
IgorMir
in reply to: Mark.Lancaster
Thanks, Mark!
I will know from now on how to handle such a task in the future. One thing I still couldn't work out though. How to introduce spacers in the formula in the spread sheet? So I get an info presented in the Description the way it is in red circle. Here is a part in IV2018 format as well.
Many Thanks!
Igor.
Message 10 of 12
jhackney1972
@IgorMir, In the spreadsheet the text values are introduced into the callout by using quotes (") for example the "x" between the values.  Since a space is just text, add it inside the quotes to get the spacing you desire.  Here is one cell formatting from the Excel spreadsheet.  Note the desired spaces added inside the quotes.
And here is the iPart table showing the spaces you desire.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Message 11 of 12
IgorMir
in reply to: jhackney1972
Terrific! Thanks, John!
Cheers,
Igor.
Message 12 of 12
Thank you, All of you guys.
The video is a great work.
What I am trying was little different. Length is of a flat pattern and I need a text before length which also changes as per member.
I did manage to do it last night.
Excel works if all of the cells are numbers. But I have the formula in one cell and changing text in another, so Excell does not accept it. The parts list then shows the formula instead of value.
So workaround as below.
I have created another part property which is Text and changes as per member. Flat pattern length I have calculated using Parameters and formula. I have created a column in the spreadsheet for this.
I have used this parameter in the part sketch and drawn a  construction line to use this parameter. The line is just to consume this parameter called "Length"
(What I have learnt is I need to use the parameter in the part itself for it to work!)
And then in Description of the part itself, I have used function =<Category><Length>
This did a trick and I got the desired result.
Parts List-1.jpgPart Description.jpgIpart Excel.jpgParameter Length.jpgUsed parameter.jpg
