Hi guys,
I have just started to learn how to use Inventor.... I am loving this software so far but finding difficult to learn on my own.
I am trying to create a rectangle panel wood with sides with different angles (700x1000mm and thick of 15mm) 2 sides need to be 45degres and the 2 other 25degres.
I have tried withh the Extrude and taper function ...but this doesn t let me create different angles(taper) on each sides.
What would be the best way to do this? What other function could i use?
I hope i was clear enought!
Thanks in advance
Solved by blair. Go to Solution.
extrude your profile with square sides, then use the Chamfer command. You could also create a sketch on the side of panel, produce a triangle of the shape of the material you wish to remove and use the extrude command, but with the "cut" option.
