Inventor General Discussion
Distinguished Contributor
1 Kudo
Post 1 of 11
Leader lines invisible
729 Views, 10 Replies
05-02-2013 02:39 PM
Recently upgraded to 2014 and now anytime I add leaders to a point inside a view, the leader disappears.  If I move the start point to the outer extremity, then it shows up fine.  Any thoughts?
______________________________________________________________
Autodesk Product Design Suite Ultimate 2014
Inventor Pro 2014 - SP1
Win7 Pro x64
Dell T5500; Xeon E5520 2.27GHz; 15 GB ECC RAM; Quaddro FX4800; SSD
I figured it out.  I had a text box that was as large as the view.  Is there a way to turn this "feature" off?  It makes no sense to clip the whole text box.  It should only clip around the text, not the entire text box.
A stupid workaround is to add all the dimensions and leaders and then center the text box over the view afterwards.  But as soon as a dimension is added or changed, they all get clipped again.
779 Kudos
Post 2 of 11
Re: Leader lines invisible
05-03-2013 12:14 AM in reply to: dloganbill
Other than check you are on the most current Microsoft certified graphics card for your system. Works fine on my home machine using the default IV template that ships with IV2014.
IV2015 SP1-ud2 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-980 Classified - 347.09
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
1 Kudo
Post 3 of 11
05-03-2013 09:01 AM in reply to: blair
I updated my driver to 320.00 and still have the same problem.
 However, now I see that it is doing it for all lines (leaders, dimensions, ordinate set)
I've tried using the default styles as well as some custom ones.
Any other ideas, my coworker next to me doesn't have this issue.
Win7 Pro x64
779 Kudos
Post 4 of 11
05-03-2013 09:24 AM in reply to: dloganbill
If you have any other issues, I might start thinking problems with the install.
You did follow the install procedure
1.) Admin Priv
2.) UAC slider set to lowest position
3.) Depending on A/V may need to stop the Anti-Virus (some problems with Norton, we use AVG without any install problems)
Win7-64
Delta Tau Chi ΔΤΧ
1 Kudo
Post 5 of 11
05-03-2013 10:12 AM in reply to: blair
No other issues so far.
I have admin privilages.  Didn't mess with UAC or A/V (Symantec Endpoint Protection).  But neither did my coworker.
Win7 Pro x64
779 Kudos
Post 6 of 11
05-03-2013 09:50 PM in reply to: dloganbill
In the Application Options>Hardware: try changing the setting from either Quality to Performance. Even try the Compatible mode.
Win7-64
Delta Tau Chi ΔΤΧ
Employee
4 Kudos
Post 7 of 11
05-06-2013 04:27 AM in reply to: blair
One of the possible reason can be that leader lines are clipped by some texts, text clipping around hatches and dimensions was implemented in 2013. See the wiki help:
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0000-What_s_N0/0001-What_s_N1/0058-Drawing58/006...
So please check whether there are some text boxes that overlap leader lines in your drawing. If this not the case of text clipping please post here some simple drawing with reproducible problem and we will take a look at this.
Stanislav Hutnan
Inventor Development
1 Kudo
Post 8 of 11
05-08-2013 02:41 PM in reply to: t_hutns
Win7 Pro x64
Employee
4 Kudos
Post 9 of 11
05-10-2013 12:54 AM in reply to: dloganbill
I’m sorry, but there is no option to turn the text box clipping off. I understand that using whole text box instead of real text area for clipping can cause problems. I will check with development here whether we can consider some changes in this behavior.
There are already similar requests in IdeaStation, you can give Kudos them for now…
http://forums.autodesk.com/t5/Inventor-IdeaStation/Text-box-in-drawing-hides-dimension-lines/idi-p/3...
http://forums.autodesk.com/t5/Inventor-IdeaStation/Fix-the-2013-Text-Box/idi-p/3748326
Thank you for your input
Stanislav Hutnan
Active Member
0 Kudos
Post 10 of 11
12-12-2013 09:38 AM in reply to: t_hutns
This is incredibly frustating. Please fix this. Perhaps a "right click -> order -> send to front/back, fwd, bkwd" option? That would be very intuitive for any Windows user.
As an ugly, brute force, work-around, you may be able to divide your text into separate boxes. It probably won't work for every scenario, but it worked for me.
