We have started using leaders with the "Model Property-Part Number" in the text field to label the detail of the part. This is much better than typing in the text in the view label field. After the leader is placed, we usually delete the leader.
The problem that I have is if you move the leader and drop it in the broken-out section of a broken view, the entire leader and text disappears. It seems that something about the leader is still in the idw, because the file size of the idw does not go back to the size before the leader was moved.
Where does the leader go?
R11.sp2
