We are modeling entire rooms with all disciplines being shown in order to locate various equipment in the space. The model is then dropped to a 2D drawing (Which is what our construction folks require to work from and our customer requires for archiving) which is historically heavily layered to show the different types of equipment (structural items, electrical items, HVAC and various piped systems) and the lineweights are set by the layers. In my business (shipbuilding) the design world may be moving readily to 3D but the construction part of it still relies very heavily on the 2D drawing to build it and layers are a very important part of that product.
Any progress on using Layers in Inventor?
I too am in the ship design/building industry and have complex models and need to regularly turn things on/off.
At the moment the best I can do is create different view representations in the assemblies with different systems/structure/fitout turned on/off, then when inserting views into drawings select the view representation.
We are in the commercial equipment transportation sector. We use View-Reps to isolate our equipment and lines. Items such as air control lines will have their own View-Rep, the same with hydraulic lines and specialized mounts. We just create a View Rep for what we want isolated and then use that View-Rep for the drawing.
In some ways it's easier that Layers in ACAD as the same component can be in a number of View Reps but only reside on a single layer in ACAD.
This question is never going to go away as long as layers exist in Inventor. We have an airline schematic dwg that I pasted into Inventor sketch. I would like to control lineweights of entire layers, but can't in Inventor.
I want to drive the Mustang but I keep being forced to pull the Model T out of the barn.
dcmorgan wrote:
whats the point of being able to create layers in Inventor if you can't assign anything to it???
agree..
1. Forget AutoCad, this is Inventor, Autocad is just lines on a screen.
2. There are Layer Control for IDW/DWG in Inventor is controlled by the Styles Manager which allows you to set Line Weights, Colors and Visibilities and if you want the item suppressed.
View the ScreenCast to really see how Inventor displays model information.
All parts (solid objects) are the same, so Inventor doesn't know a fitting from a tube run (which is a 3D sweep of an IPT)
Hello, I copied a view from one drawing to a new one with my new template.
I projected some views from the original one.
Now I have some views with a line thickness coming from the original file and the new views with a line thickness set by the template.
I see both styles (original and new).
Yes, I can change the original style to match the new one, but this is just not right (may be ok, but not right!!!)
I just can't find a way to change the original view to the styles of the new template. Soooooo frustrating!
From what I have read you don't need to use layers,for example If you know how to use the include function for pipe routes in an assembly. if you sweep your pipes you can get the swept path into your drawing by using get assembly part sketches the find the sweep path sketch and include it in the drawing you can then tweak the path to a dashed line and change the colour and thickness.
You can turn the hidden lines off by selecting the hidden line and right clicking turn off hidden line. ( thought they do reappear when you edit the part. )
There are lot of ways to skin a cat if you have a play.
It's been a nearly a decade and I have an answer for the question, "How do I change lines from one layer to another layer in an Inventor drawing .idw Sketch?"
There is a Layer command that is not in any panel that I know and will not show if typed into "Search Help & Commands...".
You can add it to the Ribbon as a User Commands by doing the following:
Clicking Layer here works generally like AutoCAD but only works for moving things from one layer to another.
You cannot choose the active layer that new lines/text will be created on (from what I can tell).
You have to select line/text - click Layer - Click dropdown (sometimes you have to unselect and reselect the dropdown) - choose the desired layer to transfer current selection.
The whole setup appears to have been an incomplete thought.
I have a similar post that is related to this. Forget the comment above Autocad is just line blah blah.
There is still the need to be able to compose your drawings to display to your liking. Colors of elements, hatch style
I would also like Screening of elements on a layer.
I want to assign layers properties by material
I want hatch style in a section to be assigned by the material.
You can add layers
https://forums.autodesk.com/t5/inventor-forum/hatch-pattern-per-material/td-p/3644892
https://forums.autodesk.com/t5/inventor-customization/assign-layers-to-materials/td-p/2871324
So how does one do 2D layouts in Inventor? you don't?
All i want to do is to get something better going than a Powerpoint with boxes on top of a picture.
i cant make a sketch in idw and make a layer for it. Layers are blank then..
I guess the answer is: Get product design suite and use Autocad or this mystical factory module/program.
