so here's the problem:
1) Original instalation version: PL, then installed US-EN language pack.
See attachment: when running EN-US pack on PL base version, Display Name remains in polish language
--- then everything was uninstalled, also all folders found on disk with Autodesk stuff was manually deleted
2) then I installed original US-EN version of Inventor.... and guess what? Display name is still in polish language.
Do I need to format my HDD to get rid of this problem or maybe you know where those names from first instalation are still stored?
thanks
Marcin,
What OS are you running?
What is the language setting in your OS?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
nooo.... those are completely two different subjects (Windows and Inventor)
it does not help, sorry
(using WIN7 64 bit, PL)
